[postgis-users] error in using lwpostgis.sql
Chip Masters chip_masters at yahoo.com
Fri Aug 19 11:40:30 PDT 2005
Ahmet,
I had similar problems building my first postgis
database. You should have a look at this thread. There
were several helpful suggestions from other postgis
and geos users that eventually fixed my problem.
http://postgis.refractions.net/pipermail/postgis-users/2005-July/008601.html
Good luck,
Chip
--- orkun <temiz at deprem.gov.tr> wrote:
> hello
> when I enter
>  /usr/local/pgsql/bin/psql -d bzk -f  \
"/usr/local/src/postgresql-8.0.3/contrib/postgis-1.0.3/lwgeom/lwpostgis.sql",
> I get so many errors like:
psql:/usr/local/src/postgresql-8.0.3/contrib/postgis-1.0.3/lwgeom/lwpostgis.sql:3150:
> ERROR:  current transaction is aborted, commands
> ignored until end of
> transaction block
> could you tell me why these errors occured ?
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain
> @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail
> message are the sender's own
> and do not necessarily represent the views and the
> opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina
> ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma
> Dairesi'ni baglayici nitelikte degildir.
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
