[postgis-users] error in using lwpostgis.sql
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Fri Aug 19 06:06:59 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of orkun
> Sent: 19 August 2005 13:37
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] error in using lwpostgis.sql
> hello
> when I enter
> /usr/local/pgsql/bin/psql -d bzk -f \
"/usr/local/src/postgresql-8.0.3/contrib/postgis-1.0.3/lwgeom/lwpostgis.sql"
> I get so many errors like:
psql:/usr/local/src/postgresql-8.0.3/contrib/postgis-1.0.3/lwgeom/lwpostgis.
sql:3150:
> ERROR: current transaction is aborted, commands ignored until end of
> transaction block
> could you tell me why these errors occured ?
> regards
> Ahmet Temiz
Hi Ahmet,
Have you installed the plpgsql language in your database before running the
lwpostgis.sql script? On your system the command should look something like
this:
/usr/local/pgsql/bin/createlang plpgsql bzk
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
