[postgis-users] error in using Contains command
david techer
davidtecher at yahoo.fr
Sun Aug 21 11:09:09 PDT 2005
Hi
fisrt all do
select postgis_full_version()
to see if postgis was compiled using proj and geos
I think U installed proj and geos using classical commands:
./configure && make && make install
so try for postgis
Use ./configure --with-proj=/usr/local
--with-geos=/usr/local/bin/geos-config
> proj-libs=/usr/local/lib/ --with-geos-libs=/usr/local/lib/",make ,make
> install" and
> I got no error.
> But when I used sql commands as:
> template1=# SELECT id, geom FROM gtest
> template1-# where geom && 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'
> template1-# AND Contains(geom,'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))');
> ERROR: contains:: operation not implemented - compile PostGIS with
> JTS or GEOS support
> what might be the problem ?
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the
> sender's own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
> postgis-users mailing list
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
