[postgis-users] centroid function
Simon O'Malley
simonom at gmail.com
Wed Aug 24 00:41:52 PDT 2005
Thanks very much for the reponses, worked a lot better.
Simon
On 8/23/05, strk at refractions.net <strk at refractions.net> wrote:
> On Tue, Aug 23, 2005 at 07:48:31PM +1200, Simon O'Malley wrote:
> > I notice the notes say computation will be more accurate if performed
> > by the GEOS module. How do you check if it is using GEOS. My
> > postgis_full_version states that GEOS is enabled but is it using it
> > for centroid????
> Yes! If GEOS is enabled there's no way to compute centroid w/out it.
> --strk;
> postgis-users mailing list
