[postgis-users] centroid function
strk at refractions.net strk at refractions.net
Tue Aug 23 01:48:30 PDT 2005
On Tue, Aug 23, 2005 at 07:48:31PM +1200, Simon O'Malley wrote:
> I notice the notes say computation will be more accurate if performed
> by the GEOS module. How do you check if it is using GEOS. My
> postgis_full_version states that GEOS is enabled but is it using it
> for centroid????
Yes! If GEOS is enabled there's no way to compute centroid w/out it.
--strk;
