[postgis-users] Problem with pgsql2shp .dbfs
Frank Koormann frank.koormann at intevation.de
Thu Aug 25 03:47:02 PDT 2005
Too much in a hurry ...
* Frank Koormann <frank.koormann at intevation.de> [050825 12:23]:
> It's the SVG_GEOM column causing the problems.
> Some technical stuff:
> - This field is far to large for a dbf-File: The specs reserve 1 Byte for
>   the field size description, as a consequence a field can be
>   265 characters  maximum.
Obviously this must be 256 characters.
Best regards,
        Frank
 Professional Service around Free Software       (http://intevation.net/)
 FreeGIS Project                                 (http://freegis.org/)
