[postgis-users] Buffer bug ?
Daniel
daniel.faivre at camptocamp.com
Fri Aug 26 05:12:54 PDT 2005
Thank u very much for your help. Here are precisions u requested:
1) vacuum, update_geometry_stats : a cron job do that daily (a daily
process is enough).
2) I tested the same request on latests versions: same problem. (We have
old versions on a server to avoid updating all our code to be compliant
to postgis 1.0 evolutions, like new geom storage format, ...). With pg 8
and postgis 1, it take more than 4000 seconds (I stopped before end). On
windows, the problem occurs too, exactly in the same way.
3) geos version: 2.1.2 (postgis 0.9.1)
4) We realized different tests on differents pc, differents os,
differents versions ... Finally, I suspect an issue with geos 2 on
requests like "buffer(collect(the_geom), nnnn)". It's probably related
to the buffer() function.
5) explain:
If we try "explain(SELECT nextval('buffer_id_seq'),9999, 'buf',
buffer(collect(lga_geom), 1000) FROM
lg_annee WHERE lga_annee='2004' and lga_nat_cdn=2 and lga_var > 0 GROUP
BY lga_annee);", we get:
QUERY PLAN
"HashAggregate (cost=8.91..8.92 rows=1 width=267)"
" -> Index Scan using lga_var_ndx on lg_annee (cost=0.00..8.69
rows=44 width=267)"
" Index Cond: (lga_var > 0::double precision)"
" Filter: ((lga_annee = 2004::smallint) AND (lga_nat_cdn = 2))"
6) splitting of the request:
6.1) CREATE TABLE temp_lg_annee_bis AS SELECT * FROM lg_annee_bis WHERE
lga_annee=2004 and lga_nat_cdn=2 and lga_var > -1; ---> 345 milliseconds
6.2) buffer computing: the bug occur
Hope this could help.
Yours,
dF
Mark Cave-Ayland wrote:
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On
>>Behalf Of Daniel
>>Sent: 25 August 2005 13:49
>>To: PostGIS Users Discussion
>>Subject: [postgis-users] Buffer bug ?
>>Hello,
>>We developped one and half year ago a Postgis application
>>with buffer()
>>computation. The first version was coded for postgre 7.3.9 and
>>postgis-cvs, and, after, with postgis 0.8 and 0.8.1
>>We upgraded a server to postgresql 7.4 and postgis 0.9.1 and
>>it doesn't
>>work anymore:
>>The request was:
>>1000) FROM
>>lg_annee_bis WHERE lga_annee=2004 and lga_nat_cdn=2 and lga_var > -1
>>GROUP BY lga_annee;
>>I've got 7500 records which verify the where condition. The
>>whole table
>>contain 15000 records. Our past attempts got an execution
>>time smaller
>>than 25-30 seconds.
>>Now, after 360 seconds, the request is not finished.
>>Furthermore, if the
>>thread is stopped (for example in spite of a web server timeout), a
>>remaining PostgreSQL thread continue to eat CPU time. Without a quick
>>"kill -9", the server hang by 100% CPU load after few minutes.
>>Here is an "explain analyze" on a reduced dataset:
>>QUERY PLAN
>>"HashAggregate (cost=1901.96..1901.97 rows=1 width=264) (actual
>>time=5316.071..5316.076 rows=1 loops=1)"
>>" -> Seq Scan on lg_annee_bis (cost=0.00..1816.64 rows=17065
>>width=264) (actual time=35.224..36.885 rows=200 loops=1)"
>>" Filter: ((lga_annee = 2004) AND (lga_nat_cdn = 2)
>>AND (lga_var
>> > -1::double precision))"
>>"Total runtime: 5316.956 ms"
>>Does anybody know something about this (supposed) issue ?
>>We are really very annoyed by this problem. Thank you very
>>much for any
>>help.
>>dF
>Hi Daniel,
>The first things to check are if you have run VACCUM ANALYZE and SELECT
>update_geometry_stats() on your new database, and whether you have altered
>the postgresql.conf shared_buffers, random_page_cost, and
>effective_cache_size parameters for your new postmaster (changing these
>options will require you to restart PostgreSQL). If that doesn't solve the
>problem then we need some more detail.
>To begin with, what version of GEOS are you using? Also, the EXPLAIN (rather
>than EXPLAIN ANALYZE) of the *full* table would be useful as well as the
>schema of the lg_annee_bis table (given by \d in psql). This is because the
>PostgreSQL query planner is quite sensitive to changes in the number of rows
>when the number of rows in the table is small.
>It would also be useful to see how much time is being spent performing just
>the buffer() operation by trying it on the data from your WHERE condition,
>e.g.
> BEGIN;
> SELECT buffer(collect(lga_geom), 1000) FROM temp_lg_annee_bis GROUP
>BY lga_annee;
> ABORT;
>BTW, is there any reason why during your upgrade you didn't go straight to
>PostgreSQL 8.0? Having the latest and greatest database always helps.
>Kind regards,
>Mark.
>WebBased Ltd
>17 Research Way
>Tamar Science Park
>Plymouth
>PL6 8BT
>T: +44 (0)1752 797131
>F: +44 (0)1752 791023
>W: http://www.webbased.co.uk
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050826/51819ce9/attachment.vcf>
