[postgis-users] Buffer bug ?
Daniel
daniel.faivre at camptocamp.com
Mon Aug 29 02:28:13 PDT 2005
Yes: it's harder for the whole community when you're away ! ;-)
My dataset is about 5 Mo, so I would not post it on a public list ...
Can I upload it on a server and give you a private access ?
I tried tests on reduced datasets, too: it works, but very slowly. Far
much slowly than with earlier versions. The execution time is
exponential. For example:
100 features: 303 ms
200 : 2478 ms
500 : 34690 ms
With our first implementation (firsts postgis versions with geos), we
got about 25 seconds for 7500 features.
Sincerely yours,
dF
strk at refractions.net wrote:
>On Fri, Aug 26, 2005 at 04:33:27PM +0100, Mark Cave-Ayland wrote:
>>Unfortunately I'm now away from work for at least a week, but I hope that
>>someone else on the list will be able to give you some help in the meantime.
>Hello guys, it looks like I'm missing something here...
>Daniel, would you post a test case for me to check out ?
>A reduced case working on your old setup and hanging
>on the new one ?
>--strk;
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050829/08f91c79/attachment.vcf>
