[postgis-users] Buffer bug ?
strk at refractions.net
Mon Aug 29 04:05:07 PDT 2005
On Mon, Aug 29, 2005 at 11:28:13AM +0200, Daniel wrote:
> Yes: it's harder for the whole community when you're away ! ;-)
> My dataset is about 5 Mo, so I would not post it on a public list ...
> Can I upload it on a server and give you a private access ?
Sure, let me know. Also, please provide full version
of "earlier" and "current" setups, so I can try against
them.
BTW: did you try keeping the postgis version and comparing
between GEOS versions ?.
--strk;
> I tried tests on reduced datasets, too: it works, but very slowly. Far
> much slowly than with earlier versions. The execution time is
> exponential. For example:
> 100 features: 303 ms
> 200 : 2478 ms
> 500 : 34690 ms
> With our first implementation (firsts postgis versions with geos), we
> got about 25 seconds for 7500 features.
> Sincerely yours,
> dF
> strk at refractions.net wrote:
> >On Fri, Aug 26, 2005 at 04:33:27PM +0100, Mark Cave-Ayland wrote:
> >>Unfortunately I'm now away from work for at least a week, but I hope that
> >>someone else on the list will be able to give you some help in the
> >>meantime.
> >Hello guys, it looks like I'm missing something here...
> >Daniel, would you post a test case for me to check out ?
> >A reduced case working on your old setup and hanging
> >on the new one ?
> >--strk;
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
