[postgis-users] MapServer subquery problem
Geodata Analysis
info at e-geodata.gr
Mon Aug 29 04:25:48 PDT 2005
Thank you very much, that solved the problem.
strk at refractions.net wrote:
>Make this change in you DATA string:
>- from(SELECT ...
>+ from (SELECT ...
>--strk;
>On Mon, Aug 29, 2005 at 01:50:29PM +0300, Geodata Analysis wrote:
>>Hi List,
>>I'm trying to add a layer from postgis in my mapfile but i get the
>>following error :
>>*Warning*: [MapServer Error]: prepare_database(): Error executing
>>POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY
>>CURSOR FOR SELECT asbinary(force_collection(force_2d(the_geom
>>from(SELECT table1.the_geom AS the_geom)),'NDR'),gid::text from table1,
>>table2 WHERE distance(table1.the_geom, table2.the_geom) < 1000) as foo
>>WHERE the_geom from(SELECT table1.the_geom AS the_geom &&
>>setSRID('BOX3D(742438.212 4108421.689,759685.98 4121357.515)'::BOX3D, -1 )'
>>Postgresql reports the error as 'ERROR: syntax error at or near "from"
>>at character 87 '
>>the line in my mapfile is :
>>DATA "the_geom from(SELECT table1.the_geom AS the_geom FROM
>>table1, table2 WHERE distance(table1.the_geom, table2.the_geom) < 1000)
>>as foo using unique gid using srid=-1"
>>1. I've tried a lot variations
>>2. If I declare the layer without the subquery, all the data is
>>displayed correctly.
>>3. If I execute the query : select the_geom from(SELECT table1.the_geom
>>AS the_geom FROM table1, table2 WHERE distance(table1.the_geom,
>>table2.the_geom) < 1000) as foo in phppgadmin, I get the correct results
>>Any ideas ?
>>Thank you
>>Stathis Stergou
>>Gis Programmer
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
