[postgis-users] Why does this take almost 3 hours?
Paul Ramsey
pramsey at refractions.net
Mon Aug 29 21:00:14 PDT 2005
Sean,
GEOS is a reflection of JTS. To the extent that native compilation
of Java code works, there is a great deal to be said for it: the
optimization is done by experts; there is no chance of introducing
errors or bad practices in the porting process. Native compiled JTS
has been found to be faster than GEOS in a number of cases (though
fixes applied to trunk by the C++ experts remove a some of them).
Unfortunately, native compiled JTS is really only available on
platforms will supported by GCJ, and Windows is among those platforms
not 100% supported. While GEOS is available on almost all GNU
supported platforms. I would love to see native compiled JTS take
over from GEOS, but I do not see GCJ coming along all that fast on
the platform side. YMMV, for sure.
Paul
On Aug 29, 2005, at 4:25 PM, Sean Gillies wrote:
> I'm seeing the recommendation to try JTS instead of GEOS in several
> threads now. Are we losing confidence in GEOS?
> Sean
> On Aug 29, 2005, at 4:46 PM, strk at refractions.net wrote:
>> Does queryByShape() detect real intersection?
>> I bet the index has nothing to do with this, it's just
>> the Intersects() function taking your time. Try to take
>> it off.
>> Then, if you can, try using JTS instead of GEOS to compare
>> performances (I can do this part for you if you send me
>> source data).
>> --strk;
>> On Mon, Aug 29, 2005 at 03:14:20PM -0600, Ethan Alpert wrote:
>>> Bill yes my nga_reg is 11 complex shapes.
>>> What I don't understand is why queryByShape() using QIX files is
>>> SO much
>>> better.
>>> -e
>>> -----Original Message-----
>>> From: postgis-users-bounces at postgis.refractions.net
>>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf
>>> Of Bill
>>> Binko
>>> Sent: Monday, August 29, 2005 3:22 PM
>>> To: PostGIS Users Discussion
>>> Subject: Re: [postgis-users] Why does this take almost 3 hours?
>>> On Mon, 29 Aug 2005, Ethan Alpert wrote:
>>>> nga_reg is basically the world admin divided up into 11 distinct
>>>> regions. My new_snaps table has 13543 records.
>>>> 2 hours and 39 minutes later pgsql2shp of the above query finished
>>>> The above query's explain analyze is:
>>>> spatialdb_sil0=> explain analyze SELECT a.catalogid, b.cii_region,
>>>> a.the_geom FROM new_snaps a, nga_reg b WHERE a.the_geom &&
>>>> b.the_geom
>>>> AND intersects(a.the_geom, b.the_geom);
>>> QUERY
>>>> PLAN
>>>> Nested Loop (cost=0.00..67.41 rows=4966 width=273) (actual
>>>> time=11.040..2397944.885 rows=13416 loops=1)
>>>> Join Filter: intersects("inner".the_geom, "outer".the_geom)
>>>> -> Seq Scan on nga_reg b (cost=0.00..1.11 rows=11 width=37)
>>> (actual
>>>> time=0.004..147.586 rows=11 loops=1)
>>>> -> Index Scan using new_snaps_spatial on new_snaps a
>>>> (cost=0.00..6.01 rows=1 width=268) (actual time=68.748..9599.432
>>>> rows=3892 loops=11)
>>>> Index Cond: (a.the_geom && "outer".the_geom)
>>>> Filter: (a.the_geom && "outer".the_geom)
>>>> Total runtime: 2397998.833 ms
>>> How many shapes are in nga_reg? When you say "basically the
>>> world admin
>>> divided into 11 districts", do you mean there are only 11
>>> shapes? If
>>> so,
>>> how complex are the shapes?
>>> There are two possibilities I can see where PostGIS would fail
>>> you in
>>> this
>>> way.
>>> One is that the nga_reg table is huge (lots of shapes). If that's
>>> the
>>> case, then PostGIS should be driving the other direction (doing a
>>> seq
>>> scan
>>> on new_snaps and using the index on nga_reg). If it's not, it is
>>> a poor
>>> query plan and perhaps the PostGIS developers can help track that
>>> down.
>>> An easy way to test this is to remove the index on new_snaps and
>>> redo
>>> your
>>> explain (and your timing test).
>>> The alternative is that you have 11 (or some other small number
>>> of) very
>>> large, very complicated shapes. If that's the case, your indexes
>>> are
>>> not
>>> going to help you since you'll end up doing an expensive intersect()
>>> operation for each pair, and most new_snaps's bouding boxes will
>>> fall
>>> within the large shape's bounding boxes. If the shapes are
>>> Collections,
>>> you might try "exploding" them so that you can get better use of the
>>> bounding boxes.
>>> I hope this helps
>>> Bill
>>> postgis-users mailing list postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
