[postgis-users] Why does this take almost 3 hours?
Sean Gillies sgillies at frii.com
Mon Aug 29 16:25:34 PDT 2005
I'm seeing the recommendation to try JTS instead of GEOS in several
threads now. Are we losing confidence in GEOS?
Sean
On Aug 29, 2005, at 4:46 PM, strk at refractions.net wrote:
> Does queryByShape() detect real intersection?
> I bet the index has nothing to do with this, it's just
> the Intersects() function taking your time. Try to take
> it off.
> Then, if you can, try using JTS instead of GEOS to compare
> performances (I can do this part for you if you send me
> source data).
> --strk;
> On Mon, Aug 29, 2005 at 03:14:20PM -0600, Ethan Alpert wrote:
>> Bill yes my nga_reg is 11 complex shapes.
>> What I don't understand is why queryByShape() using QIX files is SO
>> much
>> better.
>> -e
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Bill
>> Binko
>> Sent: Monday, August 29, 2005 3:22 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] Why does this take almost 3 hours?
>> On Mon, 29 Aug 2005, Ethan Alpert wrote:
>>> nga_reg is basically the world admin divided up into 11 distinct
>>> regions. My new_snaps table has 13543 records.
>>> 2 hours and 39 minutes later pgsql2shp of the above query finished
>>> The above query's explain analyze is:
>>> spatialdb_sil0=> explain analyze  SELECT a.catalogid, b.cii_region,
>>> a.the_geom  FROM new_snaps a, nga_reg b WHERE a.the_geom &&
>>> b.the_geom
>>> AND intersects(a.the_geom, b.the_geom);
>> QUERY
>>> PLAN
>>>  Nested Loop  (cost=0.00..67.41 rows=4966 width=273) (actual
>>> time=11.040..2397944.885 rows=13416 loops=1)
>>>    Join Filter: intersects("inner".the_geom, "outer".the_geom)
>>>    ->  Seq Scan on nga_reg b  (cost=0.00..1.11 rows=11 width=37)
>> (actual
>>> time=0.004..147.586 rows=11 loops=1)
>>>    ->  Index Scan using new_snaps_spatial on new_snaps a
>>> (cost=0.00..6.01 rows=1 width=268) (actual time=68.748..9599.432
>>> rows=3892 loops=11)
>>>          Index Cond: (a.the_geom && "outer".the_geom)
>>>          Filter: (a.the_geom && "outer".the_geom)
>>>  Total runtime: 2397998.833 ms
>> How many shapes are in nga_reg?  When you say "basically the world
>> admin
>> divided into 11 districts", do you mean there are only 11 shapes?  If
>> so,
>> how complex are the shapes?
>> There are two possibilities I can see where PostGIS would fail you in
>> this
>> way.
>> One is that the nga_reg table is huge (lots of shapes). If that's the
>> case, then PostGIS should be driving the other direction (doing a seq
>> scan
>> on new_snaps and using the index on nga_reg).  If it's not, it is a
>> poor
>> query plan and perhaps the PostGIS developers can help track that
>> down.
>> An easy way to test this is to remove the index on new_snaps and redo
>> your
>> explain (and your timing test).
>> The alternative is that you have 11 (or some other small number of)
>> very
>> large, very complicated shapes.  If that's the case, your indexes are
>> not
>> going to help you since you'll end up doing an expensive intersect()
>> operation for each pair, and most new_snaps's bouding boxes will fall
>> within the large shape's bounding boxes.  If the shapes are
>> Collections,
>> you might try "exploding" them so that you can get better use of the
>> bounding boxes.
>> I hope this helps
>> Bill
>> postgis-users mailing list postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
