[postgis-users] I can't use contains (Postgis compiled with GEOS)
Jaime Carrera
jaicarrerahdez at yahoo.com
Wed Jun 1 16:50:11 PDT 2005
Greetings all,
I'm new to postgis and am trying to show the points
located inside a polygon (I compiled PostGIS by
modifying the Makefile.config file to use GEOS:
USE_GEOS=1\ GEOS_DIR=/usr/local). I'm using the
following query:
SELECT w.id FROM weather as w, muni_mpoly as m WHERE
w.coords && m.grass_poly AND contains
(m.grass_poly,w.coords);
And get the following:
ERROR: intersects:: operation not implemented -
compile PostGIS with JTS or GEOS support
So, I'm doing something wrong here, but I don't know
what it is.
Thanks
Jaime
__________________________________________________
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
