[postgis-users] Error compiling PostGIS + GEOS
strk at refractions.net
Fri Jun 3 16:18:49 PDT 2005
The upcoming 2.1.2 GEOS version should have fixed this,
you can try downloading the "branch-2-1" branch from CVS.
--strk;
On Wed, Jun 01, 2005 at 10:51:46AM -0700, Chip Masters wrote:
> PostGIS users,
> I recently tried compiling the PostGIS 1.0.1 package
> together with the GEOS 2.1.1 package, following the
> instructions for doing so found in the README.postgis
> document included in the PostGIS distribution. I am
> using the following versions of gmake and gcc:
> GNU Make version 3.79.1
> gcc (GCC) 3.4.2
> I am trying to install on RedHat 7.3, w/ the
> 2.4.20-18.7bigmem kernel. I get the following error:
> > ../index/quadtree/QuadTreeNodeBase.cpp:149:
> `sprintf' > undeclared (first use this function)
> > ../index/quadtree/QuadTreeNodeBase.cpp:149: (Each
> > undeclared identifier is reported only once for each
> > function it appears in.)
> > make[2]: *** [QuadTreeNodeBase.lo] Error 1
> > make[2]: Leaving directory
> > `/cyc110/scratch/geos-2.1.1/source/geom'
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory
> > `/cyc110/scratch/geos-2.1.1/source'
> > make: *** [all-recursive] Error 1
> Can anyone help?
> Thanks in advance,
> Chip Masters
> chip_masters at yahoo.com
> __________________________________
> Discover Yahoo!
> Get on-the-go sports scores, stock quotes, news and more. Check it out!
> http://discover.yahoo.com/mobile.html
> postgis-users mailing list
