[postgis-users] Intersection errors
strk at refractions.net
Tue Jun 7 01:14:35 PDT 2005
I've tested this with both latest GEOS and JTS, both fail.
Also, I confirm that the MULTIPOLYGON is found to be non-valid.
--strk;
On Mon, Jun 06, 2005 at 08:29:50PM -0600, Darren Houston wrote:
> Hi Sean,
> I'm correct in assuming the multipolygon posted is the geometry at
> layer=3? I received a false isvalid on that multipolygon.
> 'POSTGIS="1.0.1" GEOS="3.0.0" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.0" RELPROC="0.3.0"'
> I'm in a rush, but I promise to look at it more tomorrow.
> Darren H.
> Sean M. Montague wrote:
> >Several months ago I had posted on this list about some intersection
> >problems I was having, but was never able to solve it. I gave up with
> >the intentions of revisiting it if version 1 did not fix the bug. It
> >has not. The problem arises when trying to intersect one poly with
> >another when it has holes. If the intersecting poly partially overlays
> >a hole, it throws an error. Below is the geometry with holes and the
> >two intersection statements. The first works, it does not intersect any
> >part of the hole. The second fails. I've tried to keep it simple.
> >Thanks.
> >Sean
> >GeometryFromText('MULTIPOLYGON(((-244339 1210399, -244339 1541250, 21058
> >1541250, 21058 1210399, -244339 1210399)),((-39283 1521307, -57692
> >1518238, -64340 1511591, -62805 1497784, -54112 1494716, -45931 1494716,
> >-40306 1494204, -38260 1493693, -34681 1482443, -42862 1471705, -50021
> >1460966, -51044 1448182, -41840 1437955, -27522 1431307, -8601 1422614,
> >603 1409318, 92 1392955, -13715 1377103, -46953 1370455, -68942 1365341,
> >-91442 1342841, -91442 1309092, -81726 1303467, -2976 1329546, 13899
> >1358182, 14921 1431818, -7067 1513125, -39283 1521307)))',32767)
> >SELECT intersection(the_geom, PolygonFromText('POLYGON((-341457 1496785,
> >-161897 1496785, -161897 1317225, -341457 1317225, -341457
> >1496785))',32767))
> >As the_geom
> >>From test_02
> >WHERE layer='3'
> >AND the_geom && PolygonFromText('POLYGON((-341457 1496785, -161897
> >1496785, -161897 1317225, -341457 1317225, -341457 1496785))',32767);
> >Returns:
> >"0103000020FF7F000001000000050000000000000098D30DC1000000006919344100000
> >00098D30DC100000000D1D636410000000048C303C100000000D1D636410000000048C30
> >3C100000000691934410000000098D30DC10000000069193441"
> >SELECT intersection(the_geom, PolygonFromText('POLYGON((-213394 1467529,
> >-33834 1467529, -33834 1287969, -213394 1287969, -213394
> >1467529))',32767))
> >As the_geom
> >>From test_02
> >WHERE layer='3'
> >AND the_geom && PolygonFromText('POLYGON((-213394 1467529, -33834
> >1467529, -33834 1287969, -213394 1287969, -213394 1467529))',32767);
> >Returns:
> >NOTICE: AssertionFailedException: EdgeRing::computePoints: found null
> >Directed Edge
> >ERROR: GEOS Intersection() threw an error!
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
