[postgis-users] [UNCLASSIFIED] SuSE 9.1 binary RPM
Antti.Roppola at brs.gov.au Antti.Roppola at brs.gov.au
Mon Jun 6 18:58:08 PDT 2005
I just finished building a binary RPM for PostGIS 1.0.0 on Postgres 7.4.2 for SuSE 9.1 (aka, not messing with the default 9.1 setup).
Here's a diff against the default spec file for Postgres in SuSE:
  http://data.brs.gov.au/mapserv/antti/suse91-postgres-postgis.spec.diff
Other than that, I think the only thing I needed to tweak was the assumed locations
of proj and geos in the PostGIS Makefile. Only the posgresql-postgis rpm needs to
be installed.
This might be a useful starting point for others wanting to play nicely with SuSE
and YaST.
Cheers,
Antti
P.S., I used the 0.6 SRPM for Red Hat as a starting point, but ended up modifying the
SuSE Postgres spec file instead.
IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF).  The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material.  It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited.  The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited.  If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments.  If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly.  Only e-mail correspondence which includes this footer, has been authorised by DAFF
