[postgis-users] PostGis to ArcCatalog
Paul Ramsey
pramsey at refractions.net
Tue Jun 7 06:21:25 PDT 2005
Bruce,
The PgArc extension, which is a first-order attempt at connectivity,
is the only working solution I am aware of. I have long wanted to
attack OleDB, but with the knowledge that it is a lot of work and
opaque code, have waited for someone to step up with funding to do
the work. If you want to attempt it yourself, I would suggest the
first thing to do would be turn on statement logging in your
PostgreSQL database so you can see what ArcCatalog is asking of your
database. That would clarify your problems relatively quickly.
For the record, I recently tried the PgOleDb libraries, and did not
get any success in ArcCatalog, even with non-spatial tables. I think
getting stuff truly working would involve a great deal of testing
across every version and patch of the Arc* suite. What Arc* version
were you testing? (I was trying Arc8)
Paul
On 7-Jun-05, at 5:24 AM, Clay, Bruce wrote:
> I am in the process of building a geo-spatial database using
> PostgreSql
> 8.0.3 with PostGis. While I seem to be able to build the database
> ok, I
> don't seem to be able to use it with ArcGis once I have built it.
> I tried to use the PgOleDb interface. This interface does connect
> ArcCatalog to the database and let me see generic tables it would not
> show any of the PostGis (POINT / POLYGON) data.
> I am trying to pin down the source of the problem but since there
> are so
> many layers (PostgreSql, PostGis, PgOleDb, ArcCatalog), I don't know
> where to begin. I have communicated with Shamchar (maintainer of
> PgOleDb) but he did not know of a fix for the problem.
> Does anyone know of any way to use PostGis data with ArcCatalog or
> ArcMap.
> The solution really needs to be an Open Source / free one to meet
> project requirements.
> Bruce
> postgis-users mailing list
