[postgis-users] Postgis Problem
Markus Schaber schabi at logix-tt.com
Fri Jun 10 01:41:19 PDT 2005
Hi, Levert,
Levert Donovan wrote:
> The postgis database works fine, but, when I want
> insert popplace.sql data, I have this error :
> 	ERROR:  couldnt parse objects in GEOMETRY
> This insert request doesn't works
> '0101000000000000406B423F4100000020B2883341'
My PostGIS can parse this fine. Maybe your PostGIS version is to old,
you nead at least PostGIS 1.0 to parse this representatin.
Can you send us the output of "SELECT postigs_full_version()" and
"SELECT postgis_version()" ?
Markus
