[postgis-users] Postgis Problem
Markus Schaber
schabi at logix-tt.com
Fri Jun 10 05:24:24 PDT 2005
Hi, Levert,
(Please keep this discussions on the list.)
Levert Donovan wrote:
> I launch psql name_database, but I have no result for
> the requests SELECT postgis_full_version()
> SELECT postgis_version()
What is the error message you get when you make those SELECTs?
Or do you simply get no output at all?
> The postgresql is : 7.4.7 version
This version is supported by PostGIS, as currently are all versions from
7.2.x up to 8.0.x, so I suspect that your PostGIS installation is either
outdated or broken.
Markus
