[postgis-users] INSERT geom Problem
Markus Schaber
schabi at logix-tt.com
Mon Jun 13 02:19:26 PDT 2005
Hi, Levert,
Levert Donovan wrote:
> But this INSERT doesn't work :
> INSERT INTO "popplace"
> ("unique_key","name","the_geom") VALUES
> ('124','London','SRID=27582;0101000000000000A053984241000000C0789A3141');
> Do you what is the format of
> 'SRID=27582;0101000000000000A053984241000000C0789A3141',
> how can I convert this to GeometryFromText() function
Try setsrid() function:
lwgeom=# select
setsrid('0101000000000000A053984241000000C0789A3141'::geometry,27582);
setsrid
0101000020BE6B0000000000A053984241000000C0789A3141
Alternatively, produce the Hex-EWKB containing the SRID yourself.
HTH,
Schabi
