[postgis-users] INSERT geom Problem
Levert Donovan
dono78fr at yahoo.fr
Mon Jun 13 03:15:20 PDT 2005
> What does "SELECT version()" spit out?
$psql -U mapuser mapcanada
mapcanada=> SELECT version();
version
PostgreSQL 7.4.7 on i686-pc-linux-gnu, compiled by
GCC gcc (GCC) 3.2 20020903 (Red Hat Linux 8.0 3.2-7)
(1 row)
> Try setsrid() function:
> lwgeom=#
>select
>setsrid('0101000000000000A053984241000000C0789A3141'::geometry,27582);
I can't do the SELECT because the INSERT doesn't
works.
select
Best Regards.
Donovan LEVERT
--- Markus Schaber <schabi at logix-tt.com> a écrit :
> Hi, Levert,
> Levert Donovan wrote:
> > But this INSERT doesn't work :
> > INSERT INTO "popplace"
> > ("unique_key","name","the_geom") VALUES
('124','London','SRID=27582;0101000000000000A053984241000000C0789A3141');
> > Do you what is the format of
'SRID=27582;0101000000000000A053984241000000C0789A3141',
> > how can I convert this to GeometryFromText()
> function
> lwgeom=# select
> setsrid
> 0101000020BE6B0000000000A053984241000000C0789A3141
> Alternatively, produce the Hex-EWKB containing the
> SRID yourself.
> HTH,
> Schabi
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
