[postgis-users] INSERT geom Problem
Markus Schaber
schabi at logix-tt.com
Mon Jun 13 04:00:50 PDT 2005
Hi, Levert,
Levert Donovan wrote:
> $psql -U mapuser mapcanada
> mapcanada=> SELECT version();
> version
> PostgreSQL 7.4.7 on i686-pc-linux-gnu, compiled by
> GCC gcc (GCC) 3.2 20020903 (Red Hat Linux 8.0 3.2-7)
> (1 row)
That looks fine.
> I can't do the SELECT because the INSERT doesn't
> works.
> select
> setsrid('0101000000000000A053984241000000C0789A3141'::geometry,27582);
You do not need any INSERT for this SELECT.
Just type "select
setsrid('0101000000000000A053984241000000C0789A3141'::geometry,27582);"
at the psql prompt.
Schabi
