[postgis-users] update Geometry_columns
strk at refractions.net
Wed Jun 15 02:11:07 PDT 2005
BEGIN;
CREATE geometry_columns_backup AS SELECT * FROM geometry_columns:
DELETE FROM geometry_columns;
SELECT probe_geometry_columns();
.. do some checks mainly for dimensions comparing backup with new
one ..
COMMIT;
The probe_geometry_columns() will not detect correct dimensions,
everything else is done checking constraints. Actually since 1.0
we do put a constraint on dimensions, so it could be possible to
add dimensions detection as well.
Note also that tables w/out strictly conformant constraints won't
be correctly detected.
Let me know if it worked :)
--strk;
On Tue, Jun 14, 2005 at 09:12:57PM -0400, Mark Fenbers wrote:
> All,
> I've made a few changes to my tables containing GEOMETRYs. I deleted
> some, created new ones with SELECT INTO, and renamed one or two. Now my
> Geometry_columns table shows tables that have been deleted, and doesn't
> show others that clearly exist. Now, using Quantum GIS, I can only
> display data from tables in Geometry_columns. Is there a magic command
> I could use to update this table to accurately reflect what in my DB
> now? Or do I have to manually delete, update, or insert rows each time
> I dork with a geometry table?
> Mark
> postgis-users mailing list
