[postgis-users] Vacuum analyse ERROR: Operation on twoGEOMETRIESwith different SRIDs
strk at refractions.net strk at refractions.net
Wed Jun 15 04:46:41 PDT 2005
Mark, I think your one is a good workaround, nonetheless having
analyze fail on full database is not very kind.
Does anyone intentionally use btree operators with postgis ?
If they are really just for system use we can rethink their
semantic, make it quiet or issue a NOTICE.
--strk;
On Wed, Jun 15, 2005 at 12:22:59PM +0100, Mark Cave-Ayland wrote:
> > -----Original Message-----
> > From: Sergey Karin [mailto:sergey.karin at gmail.com]
> > Sent: 15 June 2005 12:06
> > To: Mark Cave-Ayland (External)
> > Subject: Re: [postgis-users] Vacuum analyse ERROR: Operation
> (cut)
> > Why I have the table with a column of geometries with
> > different SRIDs. I have many layers. And I want to group they
> > in some workspaces. So, I created a table, named WORKSPACE,
> > in this table each row describes one workspace. Of cource, I
> > want to save information about boundary of each workspace.
> > And of cource the boundaries can be in different SRIDs
> > dependently of SRIDs of layers, contained in given workspace.
> > So, I have a table with column containing geometries with
> > different SRIDs...
> Hi Sergey,
> I can see why you have gone for a column with mixed SRIDs now, but I'm still
> not 100% convinced about allowing this. If you need geometries with SRIDs in
> your application, I can see a workaround:
> 	select setSRID(boundary, srid) AS boundary, setSRID(start_point,
> srid) AS 	start_point FROM workspaces WHERE id = X;
> This would then allow you to set all your SRIDs to -1 in PostGIS, but return
> geometries with SRIDs for your application. Note that if your application
> doesn't need the SRID in the geometry directly then you can still read the
> coordinates and the SRID directly, and then let your application behave
> accordingly.
> Thoughts anyone else?
> Mark.
> WebBased Ltd
> 17 Research Way
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-users mailing list
