[postgis-users] Vacuum analyse ERROR: Operation ontwoGEOMETRIESwith different SRIDs
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Jun 15 05:03:13 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 15 June 2005 12:47
> To: 'PostGIS Users Discussion'
> Subject: Re: [postgis-users] Vacuum analyse ERROR: Operation
> Mark, I think your one is a good workaround, nonetheless
> having analyze fail on full database is not very kind.
> Does anyone intentionally use btree operators with postgis ?
> If they are really just for system use we can rethink their
> semantic, make it quiet or issue a NOTICE.
> --strk;
Hi strk,
Yeah, in this case I think the application should be able to work around it,
but that's perhaps a different argument ;) I agree that clobbering users in
an ANALYZE is not a friendly thing to do, as if tables don't get ANALYZEd
then your system can end up running quite badly - but then again this is the
first complaint we've had about this so far.
As a compromise, how about just changing the semantics for the btree "less
than" and "equals" operators to the following:
	i) PG 7.1 - issue a NOTICE but continue
	ii) PG > 7.1 and PG < 8.0 - issue a WARNING but continue
As long as we document this in the relevant sections of the btree ops code
then we should be OK, since these versions are a fixed target and so we can
guarantee that no other operators will get used as part of the ANALYZE. I
don't think I would like to lessen the strictness checks any less than this
though, and it's probably not good to start shouting in the docs that
mixed-SRID columns are a supported feature ;)
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
