[postgis-users] Problem file.map to Postgis
Nicolas Ribot
nicky666 at gmail.com
Wed Jun 15 08:01:43 PDT 2005
Hi Donovan,
Apparently, the connection database does work.
The query is getting executed and Postgis error is:
ERROR: syntax error at or near "@" at character 139
You query seem to be very strange:
SELECT Capital::text,Name::text,asbinary(force_collection(force_2d(ä¶J@ä¶J@)),'NDR'),OID::text
from ì¶J@ì¶J@ WHERE ä¶J@ä¶J@ &&
setSRID('BOX3D(-2598687.33333333 -712631,3471487.33333333
3840000)'::BOX3D, find_srid('','ì¶J@ì¶J@','ä¶J@ä¶J@') )
Table names and columns are all messed up in this query.
What is your database encoding ?
You should check this.
Nicolas
On 6/14/05, Levert Donovan <dono78fr at yahoo.fr> wrote:
> Hello,
> I am newbie with Postgis, I use the tutorial example
> Gmap-demo from FGS(Maptools) and I would like to link
> a .map file with the Postgis database, but I have many
> problems.
> This is a part of file gmap75.map to a Postgis
> connection :
> LAYER
> NAME popplace
> METADATA
> "DESCRIPTION" "Cities"
> "RESULT_FIELDS" "NAME"
> END
> TYPE POINT
> STATUS ON
> DATA "the_geom FROM popplace"
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=x password=x dbname=mapcanada
> host=192.168.20.200 port=5432"
> LabelItem "Name"
> CLASSITEM "Capital"
> CLASS
> EXPRESSION "1"
> TEMPLATE "ttt_query.html"
> SYMBOL 2
> SIZE 8 .....
> The connection to database doesn't works, I activated
> verbose logs, and I see a bad format for the text,
> this is the error log :
> DEBUG: StartTransactionCommand
> LOG: statement: DECLARE mycursor BINARY CURSOR FOR
> SELECT
> -712631,3471487.33333333 3840000)'::BOX3D,
> Do you know
> Best Regards,
> LEVERT Donovan
> ___________________________________________________________________________
> Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
> Téléchargez cette version sur http://fr.messenger.yahoo.com
> postgis-users mailing list
