[postgis-users] compiling-problem under linux
Uwe Seher
uwe.seher at arteng.de
Fri Jun 17 06:13:22 PDT 2005
Hello!
i am triing to setup a geodatabase with postgis on a linuxserver (suse 9.2).
I am using postgresql 8.0.1. from a rpm.
When i try to compile postgis appear these messages in the shell:
xxxxxx:/usr/src/packages/SOURCES/postgresql-8.0.1/contrib/postgis-1.0.1 #
make
make -C lwgeom
make[1]: Entering directory
`/usr/src/packages/SOURCES/postgresql-8.0.1/contrib/postgis-1.0.1/lwgeom'
../Makefile.config:98:
/usr/src/packages/SOURCES/postgresql/postgresql-8.0.1/src/Makefile.global:
No such file or directory
Makefile:110: /src/Makefile.shlib: No such file or directory
make[1]: *** No rule to make target `/src/Makefile.shlib'. Stop.
make[1]: Leaving directory
make: *** [liblwgeom] Error 2
the requested file makefile.global doesnt exist.
Can someone help with this?
Thank you
Uwe Seher
____________
Virus checked by G DATA AntiVirusKit
