[postgis-users] compiling-problem under linux
Fenoy Gerald
djayweb at djayux.net
Fri Jun 17 06:23:06 PDT 2005
Hi, do you try to use the configure command from the current
postgresql sources that you use to compile the postgis support ?
Le 17 juin 05 à 15:13, Uwe Seher a écrit :
> Hello!
> i am triing to setup a geodatabase with postgis on a linuxserver
> (suse 9.2).
> I am using postgresql 8.0.1. from a rpm.
> When i try to compile postgis appear these messages in the shell:
> xxxxxx:/usr/src/packages/SOURCES/postgresql-8.0.1/contrib/
> postgis-1.0.1 #
> make
> make -C lwgeom
> make[1]: Entering directory
> `/usr/src/packages/SOURCES/postgresql-8.0.1/contrib/postgis-1.0.1/
> lwgeom'
> ../Makefile.config:98:
> /usr/src/packages/SOURCES/postgresql/postgresql-8.0.1/src/
> Makefile.global:
> No such file or directory
> Makefile:110: /src/Makefile.shlib: No such file or directory
> make[1]: *** No rule to make target `/src/Makefile.shlib'. Stop.
> make[1]: Leaving directory
> lwgeom'
> make: *** [liblwgeom] Error 2
> the requested file makefile.global doesnt exist.
> Can someone help with this?
> Thank you
> Uwe Seher
> ____________
> Virus checked by G DATA AntiVirusKit
> postgis-users mailing list
