[postgis-users] Upgrading to Geos 2.1.2 from 2.1.0
Fenoy Gerald
djayweb at djayux.net
Thu Jun 23 02:00:20 PDT 2005
Hi, sorry but there is something I don't understand. Indeed I
just emerge the new geos-2.1.2 ebuild then all the old databases
display :
postgis_geos_version
2.1.2
(1 row)
for the query "select postgis_geos_version();".
Furethermore I don't even upgrade or reinstall the postgis library
after upgrading the geos one ...
You must note that, at the end of an ebuild installation there is
always a call to the ldconfig command so you could maybe look on that
way ...
Hope that help.
Cordialy.
Le 23 juin 05 à 10:52, Daniel a écrit :
> What you have done isn't enough for a postgis upgrade. take a look
> at postgis docs for upgrades.
> To upgrade, you must:
> 1) dump your db. Hint: do not dump postgis functions (do it by
> script, for example)
> 2) delete your db. Hint: try a restore before.
> 2) upgrade your postgis version.
> 3) re-create your db.
> 4) enable your new postgis version for your db.
> 5) restore your data from backup.
> Yours,
> dF
> Stefano B. wrote:
>> Hi, I have upgraded geos to 2.1.2 version but when i type
>> I get "2.1.0"
>> I did the following steps:
>> 1) make uninstall (From geos 2.1.0 dir)
>> 2) compiled geos 2.1.2 and make install .... ok
>> 3) create a new postgis database from an old one with the
>> postgis_restore procedure
>> and the new database has the old version on Geos (2.1.0).
>> Why?
>> Thanks in advance.
>> Stefano
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> <daniel.faivre.vcf>
Fenoy Gerald
!!! GIS for gentoo'ers !!!
