[postgis-users] Upgrading to Geos 2.1.2 from 2.1.0
Daniel
daniel.faivre at camptocamp.com
Thu Jun 23 02:55:55 PDT 2005
That's true: it work fine this way for these minor upgrade.
Fenoy Gerald wrote:
> Hi, sorry but there is something I don't understand. Indeed I
> just emerge the new geos-2.1.2 ebuild then all the old databases
> display :
> postgis_geos_version
> 2.1.2
> (1 row)
> for the query "select postgis_geos_version();".
> Furethermore I don't even upgrade or reinstall the postgis library
> after upgrading the geos one ...
> You must note that, at the end of an ebuild installation there is
> always a call to the ldconfig command so you could maybe look on that
> way ...
> Hope that help.
> Cordialy.
> Le 23 juin 05 à 10:52, Daniel a écrit :
>> What you have done isn't enough for a postgis upgrade. take a look
>> at postgis docs for upgrades.
>> To upgrade, you must:
>> 1) dump your db. Hint: do not dump postgis functions (do it by
>> script, for example)
>> 2) delete your db. Hint: try a restore before.
>> 2) upgrade your postgis version.
>> 3) re-create your db.
>> 4) enable your new postgis version for your db.
>> 5) restore your data from backup.
>> Yours,
>> dF
>> Stefano B. wrote:
>>> Hi, I have upgraded geos to 2.1.2 version but when i type
>>> I get "2.1.0"
>>> I did the following steps:
>>> 1) make uninstall (From geos 2.1.0 dir)
>>> 2) compiled geos 2.1.2 and make install .... ok
>>> 3) create a new postgis database from an old one with the
>>> postgis_restore procedure
>>> and the new database has the old version on Geos (2.1.0).
>>> Why?
>>> Thanks in advance.
>>> Stefano
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> <daniel.faivre.vcf>
> Fenoy Gerald
> djayweb at djayux.net
> !!! GIS for gentoo'ers !!!
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050623/ee0b5ecb/attachment.vcf>
