AW: [postgis-users] postgres 8 with postgis 1 on window xp
Stephan Schuetz
s.schuetz at fhbb.ch
Tue Jun 28 01:42:12 PDT 2005
Hi
Do you have configured the Windows XP firewall to accept connections on your
postgres port?
If your firewall is active, you have to edit the configuration and open the
postgres port (Start -> Control Panel -> Windows Firewall). Add an exception
like this:
Port: [Your PostgreSQL port, by default 5432]
TCP
I hope this will help you.
Stephan
> Von: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von
Mohammed Wahead
> Gesendet: Dienstag, 28. Juni 2005 09:59
> An: postgis-users at postgis.refractions.net
> Betreff: [postgis-users] postgres 8 with postgis 1 on window xp
> Hi,
> I am having trouble making non local connections to my windows
installation of Postgres8/postGIS1. I have followed the help and added the
following entry to the to the pg_hba.conf file:
> host all all 10.0.0.1 255.255.255.0 trust
> host all all 10.0.0.0 255.255.255.0 trust
> host all all 10.0.0.0/24 trust
> I have also set the listen_addresses = parameter in the postgresql.conf
file to (*).
> If anyone has set up Postgres/PostGIS to accept client connection on a
windows set up, please let me know.
> Thanks
> Mohammed
