[postgis-users] PostGIS/Mapserver Mapfile Question
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jun 28 08:33:23 PDT 2005
Hi all,
I'm having a problem with a mapfile connection having heart burn with
the generate SQL. This is on Windows XP using a copy of the software
from the PostGIS workshop at MUM3.
POSTGIS="1.0.1" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0"
It looks like the problem is find_srid('','zcta','the_geom') where ''
the SRID is undefined! but this example follows the workshop example as
far as I can tell. So I probably am missing some step along the way. Any
ideas what?
Thanks,
   -Steve
The layer definition:
   LAYER
     NAME "zcta"
     CONNECTIONTYPE postgis
     CONNECTION "host=localhost port=5432 dbname=census password=xxxx
user=xxxx"
     DATA "the_geom from zcta"
     TYPE POLYGON
     STATUS ON
     PROJECTION
       #"proj=latlong"
       "init=epsg:4326"
     END
     CLASSITEM "water"
     CLASS
       EXPRESSION "t"
       NAME "Water"
       OUTLINECOLOR 102 102 204
       COLOR 102 102 204
     END
     CLASS
       NAME "ZCTA5"
       OUTLINECOLOR 0 0 0
       COLOR 255 255 200
     END
   END
msDrawMap(): Image handling error. Failed to draw layer named 'zcta'.
prepare_database(): Query error. Error executing POSTGIS DECLARE (the
actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
water::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text
from zcta WHERE the_geom && setSRID('BOX3D(-73.5081481933594
40.272331237793,-69.9282608032227 43.8522186279297)'::BOX3D,
find_srid('','zcta','the_geom') )'
Postgresql reports the error as 'ERROR: find_srid() - couldnt find the
corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS
table? Is there an uppercase/lowercase missmatch? '
and the table is defined:
CREATE TABLE zcta
   gid serial NOT NULL,
   area numeric,
   perimeter numeric,
   name varchar,
   the_geom geometry,
   water bool DEFAULT false,
   state char(2) DEFAULT ''::bpchar,
   CONSTRAINT zcta_pkey PRIMARY KEY (gid),
   CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
   CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL),
   CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4326)
WITH OIDS;
