[postgis-users] PostGIS/Mapserver Mapfile Question
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue Jun 28 09:27:20 PDT 2005
Hi Steve,
Did you add the geometry column using SELECT AddGeometryColumn(..) or did
you simply add a column of type geometry to your table? Try cutting and
pasting the SELECT statement on its own into psql and seeing what the
resulting error is, e.g.
SELECT
water::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text
from zcta WHERE the_geom && setSRID('BOX3D(-73.5081481933594
40.272331237793,-69.9282608032227 43.8522186279297)'::BOX3D,
find_srid('','zcta','the_geom') )
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Stephen Woodbridge
> Sent: 28 June 2005 16:33
> To: PostGIS Users Discussion
> Subject: [postgis-users] PostGIS/Mapserver Mapfile Question
> Hi all,
> I'm having a problem with a mapfile connection having heart burn with
> the generate SQL. This is on Windows XP using a copy of the software
> from the PostGIS workshop at MUM3.
> POSTGIS="1.0.1" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.0" RELPROC="0.3.0"
> It looks like the problem is find_srid('','zcta','the_geom') where ''
> the SRID is undefined! but this example follows the workshop
> example as
> far as I can tell. So I probably am missing some step along
> the way. Any
> ideas what?
> Thanks,
> -Steve
> The layer definition:
> LAYER
> NAME "zcta"
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost port=5432 dbname=census password=xxxx
> user=xxxx"
> DATA "the_geom from zcta"
> TYPE POLYGON
> STATUS ON
> PROJECTION
> #"proj=latlong"
> "init=epsg:4326"
> END
> CLASSITEM "water"
> CLASS
> EXPRESSION "t"
> NAME "Water"
> OUTLINECOLOR 102 102 204
> COLOR 102 102 204
> END
> CLASS
> NAME "ZCTA5"
> OUTLINECOLOR 0 0 0
> COLOR 255 255 200
> END
> END
> msDrawMap(): Image handling error. Failed to draw layer named 'zcta'.
> prepare_database(): Query error. Error executing POSTGIS DECLARE (the
> actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> '),gid::text
> find_srid('','zcta','the_geom') )'
> Postgresql reports the error as 'ERROR: find_srid() - couldnt
> find the
> corresponding SRID - is the geometry registered in the
> GEOMETRY_COLUMNS
> table? Is there an uppercase/lowercase missmatch? '
> and the table is defined:
> CREATE TABLE zcta
> gid serial NOT NULL,
> area numeric,
> perimeter numeric,
> name varchar,
> the_geom geometry,
> water bool DEFAULT false,
> state char(2) DEFAULT ''::bpchar,
> CONSTRAINT zcta_pkey PRIMARY KEY (gid),
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK
> (geometrytype(the_geom) =
> 'MULTIPOLYGON'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4326)
> WITH OIDS;
> postgis-users mailing list postgis-users at postgis.refractions.net
