[postgis-users] PostGIS/Mapserver Mapfile Question
Don Drake
don at drakeconsult.com
Tue Jun 28 11:36:10 PDT 2005
I just completed an upgrade of Postgres7.4/PostGIS0.9 -->
Postgres8.0.3/PostGIS1.0.1 this week using a backup and the
postgis_restore.pl script with no real problems.
The geometry_columns table (and spatial_ref..) tables were backed up and
restored just fine for me.
Did you backup/restore a single schema maybe?
-Don
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Woodbridge
Sent: Tuesday, June 28, 2005 1:03 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS/Mapserver Mapfile Question
Mark,
Awesome, that worked great.
So, what is the "correct" procedure if you want to move a table with
geometry from database to another. Obviously, backup/restore does not do
the "whole" thing.
-Steve
>>Behalf Of Stephen Woodbridge
>>Sent: 28 June 2005 18:22
>>OK, it looks like there are no entries in the geometry_columns table.
>>The zcta table is the only one that currently has a geometry column.
>>When I did the backup/restore, I did not save the
>>it there and easy way to regenerate this?
>>-Steve
> Hi Steve,
> Sorry if it wasn't clear; the SQL given before should do that job for you.
> The corrected version is:
> BEGIN;
> CREATE TABLE old_geometry_columns WITH OIDS AS SELECT * FROM
> geometry_columns;
> DELETE FROM geometry_columns;
> SELECT probe_geometry_columns();
> COMMIT;
> You can probably delete the old_geometry_columns table once you're done,
> especially as in your case it was empty to begin with :)
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-users mailing list
