[postgis-users] PostGIS/Mapserver Mapfile Question
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jun 28 16:39:46 PDT 2005
Don,
Well I did not migrate the whole shebang. I started playing with postGIS
v0.9 on a freeBSD server, then I loaded the v1.0 on the Windows XP
laptop and I moved some selected tables using backup/restore (the
postgis_restore.pl) so this is probably the root of my problem.
In general, it seems like there should be a procedure the allows me to
copy a table from one server to another even if it has geometry columns
in it. I guess I need to look at the postgis_restore.pl and backup
scripts and see what they are doing.
There also seems to be a freeze on the freeBSD ports as non of the newer
software releases have made it into the ports directory, so I am face
with another problem of how to back port the database I now have built
and working in postGIS v1.0 on XP back to the freeBSD postGIS v0.9. This
will be easier in that I would drop the outdated database there and want
to migrate the whole thing I have built on XP back to the freeBSD server.
-Steve
Don Drake wrote:
> I just completed an upgrade of Postgres7.4/PostGIS0.9 -->
> Postgres8.0.3/PostGIS1.0.1 this week using a backup and the
> postgis_restore.pl script with no real problems.
> The geometry_columns table (and spatial_ref..) tables were backed up and
> restored just fine for me.
> Did you backup/restore a single schema maybe?
> -Don
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
> Woodbridge
> Sent: Tuesday, June 28, 2005 1:03 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS/Mapserver Mapfile Question
> Mark,
> Awesome, that worked great.
> So, what is the "correct" procedure if you want to move a table with
> geometry from database to another. Obviously, backup/restore does not do
> the "whole" thing.
> -Steve
>>>Behalf Of Stephen Woodbridge
>>>Sent: 28 June 2005 18:22
>>>OK, it looks like there are no entries in the geometry_columns table.
>>>The zcta table is the only one that currently has a geometry column.
>>>When I did the backup/restore, I did not save the
>>>it there and easy way to regenerate this?
>>>-Steve
>>Hi Steve,
>>Sorry if it wasn't clear; the SQL given before should do that job for you.
>>The corrected version is:
>>BEGIN;
>>CREATE TABLE old_geometry_columns WITH OIDS AS SELECT * FROM
>>geometry_columns;
>>DELETE FROM geometry_columns;
>>SELECT probe_geometry_columns();
>>COMMIT;
>>You can probably delete the old_geometry_columns table once you're done,
>>especially as in your case it was empty to begin with :)
>>Kind regards,
>>Mark.
>>WebBased Ltd
>>17 Research Way
>>Tamar Science Park
>>Plymouth
>>PL6 8BT
>>T: +44 (0)1752 797131
>>F: +44 (0)1752 791023
>>W: http://www.webbased.co.uk
