[postgis-users] Crasher in rc2
Rod Taylor
pg at rbt.ca
Tue Mar 1 09:35:31 PST 2005
> Do you know that you can have several different PostGIS versions
> installed in parallel, in different databases, but for the same
> Postmaster instance? It should even be possible using different schemas
> inside the same database, but I did not test this yet.
I don't see how. rc2 and rc3 use the same library name (.so.1),
and ./configure --prefix= --enable-autoconf doesn't seem to change the
path the library tries to install to.
./configure --prefix=/home/rbt/te/ --libdir=/home/rbt/te
--enable-autoconf
/bin/sh /usr/ports/databases/postgresql80-server/work/postgresql-8.0.1//config/install-sh -c -m 755 liblwgeom.so.1 /usr/local/lib/postgresql/liblwgeom.so.1
cp: /usr/local/lib/postgresql/#inst.11757#: Permission denied
