[postgis-users] Crasher in rc2
Markus Schaber schabios at logi-track.com
Tue Mar 1 09:45:23 PST 2005
Hi, strk,
strk at refractions.net schrieb:
>>It should be possible having different directories, as postgresql uses
>>full qualified file names. But I have to admit that you cannot simply
>>use "make install" unmodified.
> Since you pointed out... actually you can ;)
> LPATH=/usr/src/postgis-modified make
Okay - I used a search/replace on lwpostgis.sql :-)
Here's the proof - two different compilations of the same postgis
version in two different schemas in the same database:
multipostgis=# select
schabi.postgis_lib_build_date(),schabi.postgis_version(),postgres.postgis_lib_build_date(),postgres.postgis_version();
 postgis_lib_build_date |            postgis_version            |
 2005-03-01 17:19:32    | 1.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 |
2005-03-01 17:22:27    | 1.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 Zeile)
But, besides the library path, I also needed to comment out the lines
640-642 of lwpostgis.sql because the subselect returned more than one row.
UPDATE pg_opclass
      SET opckeytype = (select oid from pg_type where typname = 'box2d')
      WHERE opcname = 'gist_geometry_ops';
I'm afraid that this could break the GIST indices for schema users, we
should constrain the subselect to current_schema(). The following should
do this:
UPDATE pg_opclass
    SET opckeytype = (SELECT oid FROM pg_type
                      WHERE typname = 'box2d'
                      AND typnamespace=(SELECT oid FROM pg_namespace
                                        WHERE nspname=current_schema()))
    AND opcnamespace = (SELECT oid from pg_namespace
                        WHERE nspname=current_schema());
Strk, could you verify this?
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
