[postgis-users] Crasher in rc2
strk at refractions.net strk at refractions.net
Tue Mar 1 09:19:48 PST 2005
On Tue, Mar 01, 2005 at 06:17:00PM +0100, Markus Schaber wrote:
> Hi, strk,
> strk at refractions.net schrieb:
> >>Do you know that you can have several different PostGIS versions
> >>installed in parallel, in different databases, but for the same
> >>Postmaster instance? It should even be possible using different schemas
> >>inside the same database, but I did not test this yet.
> > Don't try it ;)
> > You can't do it unless you have different versioned postgis libraries
> > (which is not the case between minor-version changes)
> It should be possible having different directories, as postgresql uses
> full qualified file names. But I have to admit that you cannot simply
> use "make install" unmodified.
Since you pointed out... actually you can ;)
LPATH=/usr/src/postgis-modified make
--strk;
> markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-users mailing list
