[postgis-users] Crasher in rc2
Markus Schaber
schabios at logi-track.com
Tue Mar 1 09:17:00 PST 2005
Hi, strk,
strk at refractions.net schrieb:
>>Do you know that you can have several different PostGIS versions
>>installed in parallel, in different databases, but for the same
>>Postmaster instance? It should even be possible using different schemas
>>inside the same database, but I did not test this yet.
> Don't try it ;)
> You can't do it unless you have different versioned postgis libraries
> (which is not the case between minor-version changes)
It should be possible having different directories, as postgresql uses
full qualified file names. But I have to admit that you cannot simply
use "make install" unmodified.
markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
