[postgis-users] Crasher in rc2
strk at refractions.net
Tue Mar 1 09:14:34 PST 2005
On Tue, Mar 01, 2005 at 06:12:18PM +0100, Markus Schaber wrote:
> Hi, Rod,
> Rod Taylor schrieb:
> > FreeBSD 5.3 for AMD64. I used the version located in the ports tree.
> Okay. Can you attach a debugger to the backend so we can get a stack trace?
> > Upgrading to a newer version at this time is not easily possible, but I
> > will do so eventually.
> Do you know that you can have several different PostGIS versions
> installed in parallel, in different databases, but for the same
> Postmaster instance? It should even be possible using different schemas
> inside the same database, but I did not test this yet.
Don't try it ;)
You can't do it unless you have different versioned postgis libraries
(which is not the case between minor-version changes)
--strk;
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-users mailing list
