[postgis-users] Ready for 1.0.0 ? AMD64/Linux 2.6.10/pg8.0.1
James Marca
jmarca at translab.its.uci.edu
Thu Mar 3 12:18:41 PST 2005
At approximately Wed, Mar 02, 2005 at 10:32:36AM -0800, James Marca wrote:
> At approximately Wed, Mar 02, 2005 at 05:24:48PM +0100, Markus Schaber wrote:
> > Hi, Strk,
> > strk at refractions.net schrieb:
> > > Hello users. We're trying to get 1.0.0 out.
> > The reports of crashes on AMD64 were against RC2, so let's hope that
> > they're fixed.
I've (re)compiled and (re)installed
PostgreSQL 8.0.1
PostGIS from CVS (checked out yesterday morning about 10AM PST)
Everything compiled and installed cleanly, with the single exception
noted below. I haven't yet hit a runtime crash. I also haven't had
to redo any of my Class::DBI::... scripts, which is cool. I was
afraid I'd have to rewrite lots of things in my SQL calls. I haven't
yet tried out my java programs.
I used the update perl script in utils and it worked (upgrading from
0.9.1, pg8.0.0rc1)
One problem on the install process:
The sql in lwpostgis.sql looks for the libraries in:
/usr/lib64/liblwgeom.so.1.0
but they were installed to:
/usr/lib64/postgresql/liblwgeom.so*
my make and install lines in my packaging script (Slackware style) are
(one long line)
CFLAGS="-O2" LDFLAGS="-L/lib64 -L/usr/lib64" PROJ_DIR="/usr" GEOS_DIR="/usr" LPATH="/usr/lib64" PGSQL_SRC="/mnt/lfs/tmp/postgresql-$POSTGRESQLVERSION" make
if [ $? -gt 0 ]; then
echo "ERROR: failed"
exit 1
fi
CFLAGS="-O2" LDFLAGS="-L/lib64 -L/usr/lib64" PROJ_DIR="/usr" GEOS_DIR="/usr" LPATH="/usr/lib64" PGSQL_SRC="/mnt/lfs/tmp/postgresql-$POSTGRESQLVERSION" make install DESTDIR=$PKG
It is easy enough to add a symlink to my packaging script in the next
step, but it seems strange that 'make install' would put the library in
one place, while lwpostgis.sql looks for them somewhere else. I don't
know where the make install is picking up
/usr/lib64/postgresql ... perhaps from the PostgreSQL source?
for what its worth, my flags for installing postgresql are:
SLKCFLAGS="-O2 -march=athlon64 -mtune=athlon64 -fPIC"
SLKLDFLAGS="-lstdc++ -L/lib64 -L/usr/lib64"
SLKLIBDIR="/usr/lib64"
CFLAGS="$SLKCFLAGS" \
LDFLAGS="$SLKLDFLAGS" \
./configure \
--prefix=/usr \
--libdir=$SLKLIBDIR \
--sysconfdir=/etc --with-perl \
--with-tcl \
--with-java \
--with-openssl \
--with-tclconfig=/usr/lib64 \
--with-tkconfig=/usr/lib64 \
--host=x86_64-slackware-linux-gnu
make
exit 1
fi
I will keep testing and note any problems.
