[postgis-users] compatibilité JDBC Postgis PostgreSQL
Markus Schaber
schabi at logix-tt.com
Thu Mar 3 13:45:24 PST 2005
Hi, Jean-Pierre,
Jean-Pierre Quirion schrieb:
> If you download postgis 1.0.0 jdbc2 as source code and you compile it
> with the delivered ANT build.xml, you get a jar file which contains
> two stub classes/interfaces (PGConnection for PG7.2 and
> org.postgresql.PGConnection for Postgres7.3+).
This clearly is a bug in the ANT file, it was not updated for the recend
changes.
The Makefile currently is the recommended way of building PostGIS jdbc2.
I'll see whether I can easily fix the ANT file, if not, I'll remove it.
Markus
Markus Schaber | Dipl. Informatiker | Software Development GIS
Fight against software patents in EU! http://ffii.org/
http://nosoftwarepatents.org/
