[postgis-users] collect(geom) in rc3?
strk at refractions.net
Fri Mar 4 00:14:06 PST 2005
Mike, I tried some collect() on different input and had no
problems. force_collection() didn't change collect().
You upgrade procedure is correct.
Can you use GeomAccum() or does it segfault as well ?
Can you use other array-based pgsql function ? (array_append - for example).
Can you reproduce the bug with a simple 2-small-records table ? Would
you send it here if you can ?
--strk;
On Thu, Mar 03, 2005 at 05:58:26PM -0500, Mike Leahy wrote:
> Hey all,
> I think maybe my message (below) was overlooked because I forgot to
> change the subject. Does anyone else have the same problem I've got
> with using the collect() function? Is it just a Win32 problem, or maybe
> even just my own isolated problem? Maybe someone else with RC3 can give
> the collect() function a try...
> Thanks,
> Mike
> Mike Leahy wrote:
> >Hey folks,
> >I'm going to suggest that RC3 is not ready...I just tried out the Mark's
> >installer and ran into trouble. There are still issues with MapServer
> >connectivity, which are effectively the opposite of the problem that I had with
> >RC2. To get a mapserver to draw a layer from a postgis points table using RC2,
> >I had to use the following DATA string:
> >DATA "the_geom from (select oid, place_id, entry, name, collect(the_geom) as
> >the_geom from gis_culturepoints group by oid, place_id, entry, name) as foo
> >using srid=32619 using uniqe oid"
> >It's not ideal, but I guess that the 'collect(the_geom)' solved a problem with
> >force_collection() not working, am I right? At any rate, after installing RC3
> >(with PostgreSQL 8.0.1/WinXP, etc), the same DATA string causes postgres to crash.
> >I changed the DATA string for the layer back to what it normally would be, and
> >had no problems with mapserver:
> >DATA "the_geom from gis_culturepoints using srid=32619 using uniqe oid"
> >Just to be sure, I tried the collect() function in psql from a command window,
> >and it crashed as well, so I think this is a more significant bug than just
> >MapServer connectivity:
> >testdb=# select collect(the_geom) from gis_culturepoints;
> >server closed the connection unexpectedly
> > This probably means the server terminated abnormally
> > before or while processing the request.
> >The connection to the server was lost. Attempting reset: Failed.
> >So...my first guess is that perhaps whatever fix solved the force_collection()
> >problem also broke the collect() function, though maybe something else
> >altogether has happened.
> >FYI: When I uninstalled RC2, I verified that that the postgis-related dlls and
> >sql files (that I know of) were successfully removed. I backed-up all
> >non-spatial tables, and dropped my database. After installing RC3, I recreated
> >my database, reloaded the spatial table from scripts previously generated by
> >shp2pgsql, then reloaded the other non-spatial tables. Is there anything I
> >might have missed that could be causing an incompatibility with my current
> >PosgreSQL installation and RC3?
> >Does anyone know of anything else I should mention, or any tests I should perform?
> >Kind regards,
> >Mike
> >Quoting Mark Cave-Ayland <m.cave-ayland at webbased.co.uk>:
> >>>-----Original Message-----
> >>>From: postgis-users-bounces at postgis.refractions.net
> >>>[mailto:postgis-users-bounces at postgis.refractions.net] On
> >>>Behalf Of Markus Schaber
> >>>Sent: 03 March 2005 11:14
> >>>To: PostGIS Users Discussion
> >>>Subject: Re: [postgis-users] Ready for 1.0.0 ?
> >>(cut)
> >>>Do you think an RC4 would be the correct solution to make the
> >>>people test the latest fixes? Strk could then release 1.0.0
> >>>unchanged if RC4 is fine.
> >>Yes, I think especially as strk has fixed one crashing bug since then. I'm
> >>just not convinced that RC3 has been out long enough for people to test to
> >>make sure that the Mapserver connector issues have been solved etc.
> >>>Fine. What is your experience building the jdbc2 stuff on
> >>>windows? I'm pretty shure some additional weird problems
> >>>might pop up there. You should check out the latest CVS, as
> >>>there are some Makefile changes compared to RC3 that may ease
> >>>building in your environment.
> >>The only change I've had to make so far is to change RUNCP and BUILDCP to
> >>use semi-colons instead of colons - otherwise the building under Windows
> >>fails. I don't know if it's possible to build some of this functionality
> >>into the Makefile or to just simply make a note of it in the comments
> >>somewhere.
> >>Another thing: I've compiled the JARs as standard using a 1.4 JDK. However
> >>the notes on jdbc.postgresql.org aren't particularly clear as to which
> >>versions to use. In particular, it notes that JDBC1 is obsolete with
> >>PostgreSQL 8.0. What do you think would be the best way to compile the jdbc2
> >>driver? I'm thinking of compiling with a -target 1.3 option, and including
> >>the resulting standard/debug JARs in the Win32 installer?
> >>>I think we should make as much testing as possible.
> >>Agreed. I must admit I haven't looked at the regression tests in a long time
> >>to see what coverage they give us, but I'm hoping that passing the
> >>regression tests should be a good enough indication that PostGIS works on a
> >>particular platform.
> >>Kind regards,
> >>Mark.
> >>WebBased Ltd
> >>South West Technology Centre
> >>Tamar Science Park
> >>Plymouth
> >>PL6 8BT
> >>T: +44 (0)1752 791021
> >>F: +44 (0)1752 791023
> >>W: http://www.webbased.co.uk
> >>_______________________________________________
> >>postgis-users mailing list
> >>postgis-users at postgis.refractions.net
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >This mail sent through www.mywaterloo.ca
