[postgis-users] collect(geom) in rc3?
Mike Leahy mgleahy at fes.uwaterloo.ca
Fri Mar 4 00:34:06 PST 2005
Ok, here's a sample table with two of the points from my table (does it matter
if the geometry column is not in the geometry_columns table for these tests?):
CREATE TABLE twopoints (
    the_geom geometry
COPY twopoints (the_geom) FROM stdin;
01010000206B7F0000C17B60EB0BCD2D412F0A8C13E7FE5441
01010000206B7F000064193B2FBDD72D413A1E14BB32FD5441
I tried collect(), and got the same crash.  I don't find a function called
GeomAccum() - is this the same as Accum()?  Either way, Accum() crashes the same
as collect().
I tried array_append, as you suggest, and it works fine:
testdb=# select   array_append(ARRAY[1,2], 3) as artest;
 artest
 {1,2,3}
(1 row)
Any other suggestions?
Mike
Quoting strk at refractions.net:
> Mike, I tried some collect() on different input and had no
> problems. force_collection() didn't change collect().
> You upgrade procedure is correct.
> Can you use GeomAccum() or does it segfault as well ?
> Can you use other array-based pgsql function ? (array_append - for example).
> Can you reproduce the bug with a simple 2-small-records table ? Would
> you send it here if you can ?
> --strk;
> On Thu, Mar 03, 2005 at 05:58:26PM -0500, Mike Leahy wrote:
> > Hey all,
> > I think maybe my message (below) was overlooked because I forgot to
> > change the subject.  Does anyone else have the same problem I've got
> > with using the collect() function?  Is it just a Win32 problem, or maybe
> > even just my own isolated problem?  Maybe someone else with RC3 can give
> > the collect() function a try...
> > Thanks,
> > Mike
> > Mike Leahy wrote:
> > >Hey folks,
> > >I'm going to suggest that RC3 is not ready...I just tried out the Mark's
> > >installer and ran into trouble.  There are still issues with MapServer
> > >connectivity, which are effectively the opposite of the problem that I had
> with
> > >RC2.  To get a mapserver to draw a layer from a postgis points table using
> RC2,
> > >I had to use the following DATA string:
> > >DATA "the_geom from (select oid, place_id, entry, name, collect(the_geom)
> as
> > >the_geom from gis_culturepoints group by oid, place_id, entry, name) as
> foo
> > >using srid=32619 using uniqe oid"
> > >It's not ideal, but I guess that the 'collect(the_geom)' solved a problem
> with
> > >force_collection() not working, am I right?  At any rate, after installing
> RC3
> > >(with PostgreSQL 8.0.1/WinXP, etc), the same DATA string causes postgres
> to crash.
> > >I changed the DATA string for the layer back to what it normally would be,
> and
> > >had no problems with mapserver:
> > >DATA "the_geom from gis_culturepoints using srid=32619 using uniqe oid"
> > >Just to be sure, I tried the collect() function in psql from a command
> window,
> > >and it crashed as well, so I think this is a more significant bug than
> just
> > >MapServer connectivity:
> > >testdb=# select collect(the_geom) from gis_culturepoints;
> > >server closed the connection unexpectedly
> > >        This probably means the server terminated abnormally
> > >        before or while processing the request.
> > >The connection to the server was lost. Attempting reset: Failed.
> > >So...my first guess is that perhaps whatever fix solved the
> force_collection()
> > >problem also broke the collect() function, though maybe something else
> > >altogether has happened.
> > >FYI: When I uninstalled RC2, I verified that that the postgis-related dlls
> and
> > >sql files (that I know of) were successfully removed.  I backed-up all
> > >non-spatial tables, and dropped my database.  After installing RC3, I
> recreated
> > >my database, reloaded the spatial table from scripts previously generated
> by
> > >shp2pgsql, then reloaded the other non-spatial tables.  Is there anything
> I
> > >might have missed that could be causing an incompatibility with my
> current
> > >PosgreSQL installation and RC3?
> > >Does anyone know of anything else I should mention, or any tests I should
> perform?
> > >Kind regards,
> > >Mike
> > >Quoting Mark Cave-Ayland <m.cave-ayland at webbased.co.uk>:
> > >>>-----Original Message-----
> > >>>From: postgis-users-bounces at postgis.refractions.net
> > >>>[mailto:postgis-users-bounces at postgis.refractions.net] On
> > >>>Behalf Of Markus Schaber
> > >>>Sent: 03 March 2005 11:14
> > >>>To: PostGIS Users Discussion
> > >>>Subject: Re: [postgis-users] Ready for 1.0.0 ?
> > >>(cut)
> > >>>Do you think an RC4 would be the correct solution to make the
> > >>>people test the latest fixes? Strk could then release 1.0.0
> > >>>unchanged if RC4 is fine.
> > >>Yes, I think especially as strk has fixed one crashing bug since then.
> I'm
> > >>just not convinced that RC3 has been out long enough for people to test
> to
> > >>make sure that the Mapserver connector issues have been solved etc.
> > >>>Fine. What is your experience building the jdbc2 stuff on
> > >>>windows? I'm pretty shure some additional weird problems
> > >>>might pop up there. You should check out the latest CVS, as
> > >>>there are some Makefile changes compared to RC3 that may ease
> > >>>building in your environment.
> > >>The only change I've had to make so far is to change RUNCP and BUILDCP
> to
> > >>use semi-colons instead of colons - otherwise the building under Windows
> > >>fails. I don't know if it's possible to build some of this functionality
> > >>into the Makefile or to just simply make a note of it in the comments
> > >>somewhere.
> > >>Another thing: I've compiled the JARs as standard using a 1.4 JDK.
> However
> > >>the notes on jdbc.postgresql.org aren't particularly clear as to which
> > >>versions to use. In particular, it notes that JDBC1 is obsolete with
> > >>PostgreSQL 8.0. What do you think would be the best way to compile the
> jdbc2
> > >>driver? I'm thinking of compiling with a -target 1.3 option, and
> including
> > >>the resulting standard/debug JARs in the Win32 installer?
> > >>>I think we should make as much testing as possible.
> > >>Agreed. I must admit I haven't looked at the regression tests in a long
> time
> > >>to see what coverage they give us, but I'm hoping that passing the
> > >>regression tests should be a good enough indication that PostGIS works on
> a
> > >>particular platform.
> > >>Kind regards,
> > >>Mark.
> > >>WebBased Ltd
> > >>South West Technology Centre
> > >>Tamar Science Park
> > >>Plymouth
> > >>PL6 8BT
> > >>T: +44 (0)1752 791021
> > >>F: +44 (0)1752 791023
> > >>W: http://www.webbased.co.uk
> > >>_______________________________________________
> > >>postgis-users mailing list
> > >>postgis-users at postgis.refractions.net
> > >>http://postgis.refractions.net/mailman/listinfo/postgis-users
> > >This mail sent through www.mywaterloo.ca
