[postgis-users] loading shapefiles into postgis db
Shaq Gbadebo s_gbadebo at hotmail.com
Fri Mar 4 05:55:28 PST 2005
Thanks again for your reply Jean David. Here is what happens; when I try
that approach:
emmet=# DROP TABLE countyRegion;
DROP TABLE
emmet-# \q
bash-2.05b$ shp2pgsql -D COUNTY_region.shp myschema.countyRegion | psql -d
emmet
shape is null
bash-2.05b$ psql emmet
Welcome to psql 7.3.4, the PostgreSQL interactive terminal.
Type:  \copyright for distribution terms
       \h for help with SQL commands
       \? for help on internal slash commands
       \g or terminate with semicolon to execute query
       \q to quit
emmet=# select * from countyRegion;
ERROR:  Relation "countyregion" does not exist
Imply that the table has not been created with the shp2pgsql command.
Should the table not be created manually?
Your reply will be appreciated.
