[postgis-users] CLUSTER PostGIS table
strk at refractions.net
Wed Mar 9 13:38:26 PST 2005
On Wed, Mar 09, 2005 at 04:23:28PM +0100, Bernhard Reimar Hoefle wrote:
> Hi!
> I tried to CLUSTER a table (which holds also NULL values) with PostGIS geometry
> on the gist index.
> I get the following message:
> ERROR: cannot cluster when index access method does not handle null values
I didn't know we weren't supporting null values.
Indeed we do... should check in pgsql manuals, but I'm pretty busy
these days.
> HINT: You may be able to work around this by marking column "geom_point" NOT
> NULL.
> Does it make sense to CLUSTER the table on the geometry index (gist)?
> Is there a different way to reorganise a huge table with geometry columns to get
> better performance for spatial queries? p.s. I have 1 3D POINT geometry per
> row.
a REINDEX ?
--strk;
> Thanks in advance,
> Bernhard
> postgis-users mailing list
