[postgis-users] Postgis errors
Brent Wood pcreso at pcreso.com
Thu Mar 10 17:32:36 PST 2005
--- Paul Ramsey <pramsey at refractions.net> wrote:
> Brent,
Thanks Paul...
 isvalid() says that the geometries which failed geomunion are in fact valid.
> You have some quite old versions there. geos-2 has improved topology
> handling, which is your problem area. Also remember to check isvalid()
> on your geometries, just in case. Invalid geometries cause topology
> problems.
> You could upgrade to postgis 0.9 and geos-2 relatively easily, and
> things might be better.
I'll ask nicely :-)
Appreciated...
   Brent
