[postgis-users] PHP access to PostGIS
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 10 18:51:18 PST 2005
Hi all,
I new to working with PostGIS. I'm using PHP and I need to get my
ployline into a PHP array. What is the best way to do this?
What I'm doing so far is:
// get the segment and offset the point right/left
// retrieve the segment geometry
$sql = "select AsText(geom) as geom from geocode" .
" where id = $this->oRefId";
// execute SQL query
$result = @pg_query($this->conn, $sql);
if (!$result) {
return false;
// get the number of rows in the resultset - must be one
$rows = pg_num_rows($result);
if ($rows < 1) {
return false;
// read the points
$row = pg_fetch_array($result, 0, PGSQL_ASSOC);
print_r($row);
echo "<br>\n";
Which gives me:
Array ( [geom] => LINESTRING(-73.338249206543
41.1630020141602,-73.3395233154297 41.1648445129395) )
So I'm wondering if I need to parse the text, or if there is an easier
way this into a PHP structure, like:
$line = [ [-73.338249206543, 41.1630020141602],
[-73.3395233154297, 41.1648445129395] ];
or some other array structure.
-Steve W.
