[postgis-users] Error while importing data
Nigel Kukard
nkukard at lbsd.net
Fri Mar 11 01:31:25 PST 2005
Hi Strk,
cvs seems to fix the multiline string bug...
not sure if this is also related but i get hundreds of these errors...
help would be greatly appreciated...
You are now connected to database "all".
NOTICE: CREATE TABLE will create implicit sequence
"boundary_line_gid_seq" for serial column "boundary_line.gid"
CREATE TABLE
addgeometrycolumn
public.boundary_line.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
geometry_column fixed:0
(1 row)
BEGIN
ERROR: new row for relation "boundary_line" violates check constraint
"enforce_dims_the_geom"
CONTEXT: COPY boundary_line, line 1: "15238677 #005:134087 STATE
FOREST LINE 3227CA A 0
\N 000000000000000000000001 0 \N RSWART
0 0 200201..."
ROLLBACK
BEGIN
CONTEXT: COPY boundary_line, line 1: "12845197 FORT PATO
CONSERVATION LINE 3227DC A 0
0 0 20020621..."
ROLLBACK
BEGIN
CONTEXT: COPY boundary_line, line 1: "8291673 #001:111115535
CONSERVATION LINE 3227DD A 0
\N 000000000000000000000002 20021219 \N
MDP_2 0 ..."
ROLLBACK
strk at refractions.net wrote:
>On Thu, Mar 10, 2005 at 06:00:20AM +0000, Nigel Kukard wrote:
>>Hi Guys,
>>I'm new to postgis. I got shape files from our local government,
>>containing all data for South Afica.
>>I installed postgresql 8.0.0, postgis 1.0.0-rc3, proj 4.4.9, gdal 1.2.5,
>>php-5.0.3 & mapserver 4.4.1
>>The first thing i did is pipe lwpostgis.sql & spatial_ref_sys.sql into
>>pgsql.
>>I continued to run shp2pgsql on one of the shape files to insert it into
>>my database with
>>shp2pgsql -d drainagexxxxx.shp drainage > /tmp/postgis.sql
>>I then tried to pipe the /tmp/postgis.sql into postgresql, but got the
>>following error...
>>BEGIN
>>NOTICE: CREATE TABLE will create implicit sequence "drainage_gid_seq"
>>for serial column "drainage.gid"
>>CREATE TABLE
>> addgeometrycolumn
>>public.drainage.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
>>(1 row)
>>ERROR: Invalid type in wbk
>Nigel, we have fixed a (Multi)LineString-related bug in shp2pgsql.
>If you can test a CVS snapshot that would help us release RC4.
>--strk;
>>ERROR: current transaction is aborted, commands ignored until end of
>>transaction block
>>transaction block
>>transaction block
>>ROLLBACK
>>most of the shape files import fine, there are a couple of types which
>>give me the above error.
>>any help would greatly be appreciated, if need be I can attach the
>>actual sql file or any other info needed.
>>Regards
>>Nigel Kukard
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
Nigel Kukard, PhD CompSc
(Chief Executive Officer)
Linux Based Systems Design
Web: www.lbsd.net Email: nkukard at lbsd.net
Tel: (+27) 023 349 8000 Cell: (+27) 082 333 3723
Fax: (+27) 023 349 1395 Support: 086 747 7600
Address: LIGT House, 2 Klipdrift Rd, Rawsonville
Linux Systems Design & Technology Solutions
The best language to use is the language that was designed for
what you want to use it for.
Disclaimer
The contents of this message and any attachments are intended
solely for the addressee's use and may be legally privileged and/or
confidential information. This message may not be retained,
distributed, copied or used if you are not he addressee of this
message. If this message was sent to you in error, please notify
the sender immediately by reply e-mail and then destroy the message
and any copies thereof.
Opinions, conclusions and other information in this message may be
personal to the sender and is not that of Linux Based Systems Design,
LinuxRulz or any of it's subsideries, associated companies or
principals and is therefore not endorsed by Linux Based Systems
Design or LinuxRulz. Due to e-maill communication being insecure,
Linux Based Systems Design and LinuxRulz do not guarantee
confidentiality, security, accuracy or performance of the e-mail.
Any liability for viruses is excluded to the fullest extent.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050311/883937f1/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050311/883937f1/attachment.pgp>
