[postgis-users] Error while importing data
strk at refractions.net strk at refractions.net
Thu Mar 10 08:20:16 PST 2005
On Thu, Mar 10, 2005 at 06:00:20AM +0000, Nigel Kukard wrote:
> Hi Guys,
> I'm new to postgis. I got shape files from our local government,
> containing all data for South Afica.
> I installed postgresql 8.0.0, postgis 1.0.0-rc3, proj 4.4.9, gdal 1.2.5,
> php-5.0.3 & mapserver 4.4.1
> The first thing i did is pipe lwpostgis.sql & spatial_ref_sys.sql into
> pgsql.
> I continued to run shp2pgsql on one of the shape files to insert it into
> my database with
> shp2pgsql -d drainagexxxxx.shp drainage > /tmp/postgis.sql
> I then tried to pipe the /tmp/postgis.sql into postgresql,  but got the
> following error...
> BEGIN
> NOTICE:  CREATE TABLE will create implicit sequence "drainage_gid_seq"
> for serial column "drainage.gid"
> CREATE TABLE
>                                   addgeometrycolumn
> public.drainage.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
> geometry_column fixed:0
> (1 row)
> ERROR:  Invalid type in wbk
Nigel, we have fixed a (Multi)LineString-related bug in shp2pgsql.
If you can test a CVS snapshot that would help us release RC4.
--strk;
> ERROR:  current transaction is aborted, commands ignored until end of
> transaction block
> transaction block
> transaction block
> ROLLBACK
> most of the shape files import fine, there are a couple of types which
> give me the above error.
> any help would greatly be appreciated, if need be I can attach the
> actual sql file or any other info needed.
> Regards
> Nigel Kukard
> postgis-users mailing list
